what power supply are you using?
Ok, my PS when up in smoke last weekend so I'm in the market for a new one (or two...one for home and one to go). Whats out there that puts out 15-30 amps how much?
OFNA Power Supply
12 VCD, 18A, 110 VAC Part#: 92136 http://www.ofna.com/images/electrica...6-char-BIG.jpg |
I am using a ProPeak 20amp to run my Checkpoint T1030 and Ice chargers without any problems.
Also, that is a expensive for the Ofna one. I can get them at my track for $50 out the door. I believe it is the same one. Nick |
I use two supplies, a 20amp Propeak and 25amp Radio Shack. Both have been solid and I've used either to run both my 0610iNet Hyperions chargers.
Amain has that Ofna PS for $85... I'd consider this one if I needed another - http://store.buyreliant.com/servlet/...manuals/Detail |
I am using a modified PC P/S. I think I spent $5 to get it going.
Originally Posted by Duster_360
(Post 6549949)
I'm using the ProPeak 20amp. I've had it powering 3 chargers at a time with no problems.
Thanks for all the replies. I was running the 20 amp propeak and that is the one that crapped out on me. Apparently it doesn't have a fuse or other overcurrent protection as a friend tapped in and we were overdrawing the thing. lol
Trying to go on the cheap I've been looking at a computer PS as the most likely option atm. Newegg has some nice ones for $40 apiece or less shipped. |
Using a HP J4839A power supply for a ProCurve 41xx/53xx modular network switch.
24V at 23A. While I had to disassemble it to examine the connector outputs and build a harness out of an old ATX power extension cord, it was worth the effort. Powers my Hyperion DUO3 effortlessly. DF Edit: Corrected part number. You can get these for under $100 on Ebay. They are designed for 24x7x365 operation and are tough nuts. All high quality transformers and caps inside :) |
Originally Posted by Grizzbob
(Post 6550031)
I also have the Radio Shack 25 amp model, & it's been working perfectly for over 3 years for me(which is pretty odd given how cheap most of RS's stuff can be). I believe they actually get theirs from the same people that make a PS for Competition Electronics(which is rated at 23 amps & usually sells for about $30 more). If you can find the Radio Shack one, I highly reccomend it....:cool:
Thats a prob with the switching supplies I've seen, they don't seem to last long if you're using them at the high end of their capacity. I've pushed mine a time or two - two 0610iNet Hyperions charging at 10amps each and the smell it left in the room was a warning. Reason I added the other supply. |
| All times are GMT -7. It is currently 10:08 PM. |
