servo horn screw??
ok so the screw that hold my servo horn on, the one that came with it, apparently it came out. bc the horn came off.:cry::cry: how do i get another screw for this particular servo? its a jrz590m. please help!!! so i can be :tire::tire: again
Only thing a search turns up -
http://www.amainhobbies.com/product_...Horns-w-Screws Use a serrated or star washer under the screw and/or some blue loctite - keep it from shutting you down again. |
aren't those just ordinary 3mm Botton screws? I mean, a hardware store which sells a 3mm x 5mm botton top screws should be a good replacement for it.
Originally Posted by Duster_360
(Post 6473321)
http://www.amainhobbies.com/product_...Horns-w-Screws Use a serrated or star washer under the screw and/or some blue loctite - keep it from shutting you down again. Or like Wile E Coyote said just a standard 3mm X 5mm (or 8mm) screw will do. |
i just fixed it. i used a clutch bell screw. worked great, and of course this time i added a little locktite.:nod: thanks guys
Originally Posted by iraqsucks
(Post 6480593)
why blue of course:cool:
| All times are GMT -7. It is currently 08:30 AM. |
