Spektrum receiver help >
Old 10-08-2009 | 12:53 PM
Suspended
Default Spektrum receiver help
If the receiver antenna becomes loose does that mean it needs to be replaced? Or can i put some ca glue on it so its not loose
LosiDriver4Life is offline
Old 10-08-2009 | 01:37 PM
You need to determine if it is loose where it connects to the circuit board that is inside the receiver case. If so, a small bit of solder will fix. If the board broke and the wire is loose, the receiver would need to be repaired by Horizon.
nutz4rcyktw is offline
Old 10-08-2009 | 01:51 PM
Suspended
I removed the case. Im not sure what you mean though. I can move the antenna up and down but it wont come off. So its still on there
