Lipo Question
I just bought an extra lipo off ebay and plugged it into my balancer and charger. It is a 4c lipo and it being reported as 16.5V even though the max should be 14.8?
Should I not use it. Is it OK to discharge and use?
Thoughts?
Thoughts?
Lipos can be confusing cause there are 3 voltages talked about - a min voltage, a max voltage and a nominal voltage. Min voltage is somewhere around 3v/cell (don't discharge below this), max voltage is 4.2v/cell (this is what the cells are charged to by a lipo charging protocol) an the nominal voltage of 3.7v.cell. This is supposedly what the cell voltage is when the cell is being discharged.
4S can be as much as 16.8v (4.2 x 4), so your lipo is fine as pointed above.
When I was charging another 4 cell lipo on my TP-1010C with a 210v balancer I let it get to 16.8V expecting it to shiut itself off. When it hit 16.8, I was surprised to see it kept charging. I needed to shut it down manually.
It simply wasn't done charging yet.
You let it charge thru the constant current stage (CC). Lipo charge protocol switches to constant voltage (CV) when the cells reach max voltage. You watch next time and you'll see the current decrease at constant voltage as the lipo finishes topping off. Current will get very close to or down to zero and if the balancer is satisfied with balance between cells, charger will signal charge complete and terminate. Try it next time.
Freaks nearly everybody out the 1st time if you don't know whats going on. Chargers that have a "fast" lipo charge setting - they just stop after the CC stage to save time. The CV stage takes the longest and puts in the smallest part of the lipo's capacity.
