FM 3pk Glitching issues? >
Old 08-24-2009 | 04:42 PM
FactoryRacing23's Avatar
Default 3s Thunder Power, Dead cell? Plz Help.
I have a Thunder Power 3s lipo battery that has like 2 charges on it. I tryed to charge it on a GT power lipo charger and it says that the voltage is to low when I pick 3s to charge up the battery? does this mean that I have a dead cell? I cant plug in the balance port as I need a adapter for it to work.. If the cell is dead will Thunder Power replace the battery?
Thanks, Nick
FactoryRacing23 is offline
Old 08-26-2009 | 09:26 AM
Your charger doesnt like what it is seeing and wont charge the battery. If you ran or discharged the battery too much one of your cells could have droped below LVC point making the charger think that the battery is damaged. It is a safety protocall. How did the battery drop below LVC? Was the battery hot last time you discharged it? You need to get the adapter for the balancer, that is a must and probibly the cause for this issue. The one cell could be way out of balance but not be damaged there are ways to fix that, although no one would recoment it! Until you get a balancer or get some voltage readings per cell, I wouldnt touch it!
Prophetz is offline
Old 08-27-2009 | 05:14 AM
Thanks, Nick
Contact Thunder Power... they are good people to deal with.
they also have a support thead on HobbyTalk.
Chuck
chuck_thehammer is offline
