-   -   Servo ? (https://www.rctech.net/forum/radio-electronics/320716-servo.html)
TNHEADDUCK 08-18-2009 07:20 AM
Servo ?
I have a servo that when you pull the trigger on the radio it goes to wide open throttle posistion no matter how far you move it, does this usally mean the servo is bad. Also would a way to ck it be to swap the wires around with with the steering servo and see what happens then? :confused:
TNHEADDUCK 08-18-2009 12:06 PM
need a little advice
Surely someone has some insight to this problem i am having.
SSmith 08-18-2009 12:16 PM
Try a diff. servo in the same chan. like steeing in throtle vs throtle in steeing. I would take off the servo horns first and try one at a time. post how you made out. thanks Sean Smith
TNHEADDUCK 08-19-2009 05:16 AM
servo
Rebound the reciever to another channel on my radio and all is well now, when i changed the servo wires around it had the same action all or nothing.
Live and learn!!!!!
