JR Z650 SERVO PROBLEMS
I have gone through 3 of these servos in the past month. is this a problem anyone else is having or do you suspect a problem with my setup?? i was running 1 for steering and 1 for throttle. when the first steering took a crap i went with the 9100s. the same day the throttle went out. i replaced it with another 650 and it lasted 2 runs on the track then went out. they have all done the same thing. they will stop but if you apply pressure you can get them to work again for a min till they go to a neutral possition. then there dead again... thanks for any help
