Thunder Power RC TP-610C
Hello all,
My old charger just decided to die - so I made a trip to the LHS and ended up coming home with a TP-610C.
What is the circuit board for and how am I to use it?
Thanks a lot.
Thanks a lot.
That circuit board device is the connector board for a number of different balancing connectors(one type on it is the Align(?) connector that MC & several others use on their batteries & the others are Thunder Power's own balance connector, both for handling 2-6 cell packs). you just plug the pack's balance connector to the appropriate one on that board(as well as the main charge leads to the main wires from the battery) & then start it up....
Your new charger is a balancing charger - charges and balances lipo at same time which is the best way to maintain a lipo battery. The board is for the lipo's balance connection as mentioned above - you connect both sets of wires - the main power and the balance wires to balance charge.
Have you read the manual that comes with the charger ?
http://www.robotmarketplace.com/prod...610_Manual.pdf
Most will allow a non balance charge including this charger
Cheers
Cheers
