Airtronics M11 Help
Just purchased an M11 from a gentlemen on here. Just wondering if there is a master reset button or sequence of buttons that I can use to reset all parameters to factory settings? Thanks in advance.
Too much too type, for me anyway
www.airtronics.net/manual/M11Manual.pdf
CLEARING MODEL DATA
Using the function select keys, move the cursor to
[COPY/CLEAR] in MODEL.
Using the key, change the current model (Master) to
(Slave).
Press both INC/+ or DEC/- keys simultaneously to select
the (- - -:CLEAR) model.
Now press the ENTER key to select. The screen will
change and ask, YES=<INC> or NO=<DEC>. Select yes
to clear the current model or no to return to the previous
screen. This operation clears all data for models M01 to
M30.
NOTE:
CLEAR can be selected by simultaneously pressing
Inc/+ and Dec/-.
While clearing is in progress, the message EXECUTING!
appears until operation is completed.
This function enables you to copy data from the currently selected model to another, or to copy another model’s data into the model
currently selected. Data can be cleared (initialize) on the current model that is selected.
Here is the info you can clear each model but there is no master to blank everything have to go the each model one by one.
(Slave).
M30.
NOTE:
Inc/+ and Dec/-.
Crazy Horse
If it's like futaba though this doesn't totally reset every single parameter. Like on futaba even doing the reset it doesn't change the rx type (t-fhss s-fhss ect) and a few other parameters. I usually do the reset then copy over one of the profiles I've never used on top of any that I have (copy slot 50 to slot 1 2 3 ect) to get to a 100% fresh state.
