Lipo or not?
Old 07-10-2009 | 02:03 PM
Default Lipo or not?
I have a traxxas 1/16 scale vehicle and use the powercell nimh packs. Should I go lipo? Will it increase runtime? Do they ever loose power like nimh after you use them over and over for a while? The only thing is the cost but let me know what you think about lipo. Thanks!
gulfexports159 is offline
Old 07-10-2009 | 02:19 PM
JeromeK99's Avatar
I'd go for the LiPo! They generate almost no heat.. can be charged back-to-back and run all day long... they dont need maintenance... and they will preform and last longer than NiMh.. Runtime will also be longer for the same mah rating..
Jerome
JeromeK99 is offline
Old 07-10-2009 | 02:50 PM
Go lipo - when I switched, my runtimes went up 30%. It seems expensive, but they are cheaper than NiMh when you figure a per run cost and have next to nothing for maintenance. They do wear out, but it takes a lot of cycles before you start seeing that if you maintain them (balancing).
I def don't regret making the change!
Duster_360 is offline
Old 07-10-2009 | 08:46 PM
go with 11.1v lipo you will be looking at almost 70mph worth of power.
topsp33d is offline
Old 07-11-2009 | 03:46 PM
Default New to R/C.
Hey, I just bought an Associated SC10 and I'm clueless to which battery and charger to run with. I tried searching, but can't find a direct answer).
I want Lipo due to the run time, but I don't want to burn the stock motor like my friend did the first day with his SC10. Any/All advice is appreciated, thanks!
derffred is offline
Old 07-11-2009 | 06:58 PM
JonesyCGY's Avatar
Go Lipo if you can afford it, but one thing you need to be cautious about is over discharging them. Your ESC may not be Lipo friendly, which means it may not have the voltage cutoff protection to protect your lipos. Just be sure when you feel the power start to leave you batteries its time to stop and charge them.
JonesyCGY is offline
Old 07-11-2009 | 07:00 PM
Well, I've already decided I want Lipo, BUT... I don't know which one to get, which mAh, volts, etc.
derffred is offline
Old 07-11-2009 | 07:05 PM
Check out the Zippy Lipos at Hobbycity.com. They have several packs that are a direct fit. I have been using them in several cars for awhile now and they perform as good or better than some over-priced name brand batteries i have.
burnineyes is offline
Old 07-11-2009 | 07:09 PM
For the SC10, look at the 4000mah 7.4V Zippy Car Pack.
For the Mini Revo, I know the Rhino 1750mah 7.4V pack fits.
