Mamba Max 6900 HELP
I just got a Mamba Max 6900, I plug in the battery and turn it on and it beeps. The light stays red tho, and if I give it throttle the green light blinks and nothin happens. What does that mean? I bought this used, I know it works because I ran a battery through it once. Please help me out. Thanks
When you turn on the transmitter then turn on the esc and it beeps push the throttle for 3-4 seconds(a green light should come on). Then you'll her it beeps after a moment.
Then put on the brake, you'll see it turn green. Keep it on the brake position for 3-4 seconds. It should beep again.
Then put it in neatral all together(let off the trigger all together) you'll hear beeps. Wait about 5 seconds and your ready to go.
Make sure everything is pluged correct and your cells are peaked.
Might be off topic but I run Castle stuff in my mini latemodel with a DX3R and I MUST turn on my radio first or the esc will not work. I know your supose to turn your radio on first anyway but with 2.4 ghz and the built in failsafe it really isn't a big deal.
