does the dx3r (DSM2) support DSM receivers? >
Old 05-03-2009 | 09:22 AM
teeforb's Avatar
Default does the dx3r (DSM2) support DSM receivers?
and will the channel mixing work on the DSM receivers too?
thx
teeforb is offline
Old 05-03-2009 | 10:19 AM
SuperSmoove's Avatar
the DX3R has reverse tech, meaning all spektrum rx from the past will bind to it.
SuperSmoove is offline
Old 05-03-2009 | 10:22 AM
teeforb's Avatar
PERFECT, thanks.
can you use the AUX on the previous DSM receiver as a third channel?
teeforb is offline
Old 05-03-2009 | 02:44 PM
Trips's Avatar
The aux is the third channel.
Trips is offline
Old 05-03-2009 | 03:34 PM
I think there is one receiver exception for the DX3R, the SR3000HRS for the Futaba 3PK HRS.
Dave H is offline
Old 05-04-2009 | 06:07 PM
teeforb's Avatar
does the dx3r do model match with DSM1 receivers?
teeforb is offline
Old 05-04-2009 | 06:13 PM
RCGaryK's Avatar
That's true, but then again the only thing that will work with the HRS receiver is the HRS module, so that's not much of a difference from the past
Yes, ModelMatch is a function of the radio, not receivers.
RCGaryK is offline
Old 05-04-2009 | 06:59 PM
teeforb's Avatar
Okay, one more question :0)
Can you set your servo normal or reverse for each master slave in the channel mixing?
teeforb is offline
