Extending Servo Wires >
Old 04-18-2009 | 05:24 AM
scrapen's Avatar
Default Extending Servo Wires
I put in a new servo in my Slash but the wire is shorter then the old servo what is the best way to extend them?
scrapen is offline
Old 04-18-2009 | 05:29 AM
LOW ET's Avatar
look here: http://www3.towerhobbies.com/cgi-bin...AdvancedSearch
LOW ET is offline
Old 04-18-2009 | 05:42 AM
scrapen's Avatar
Thank you for the link I will check it out. I was kinda wondering if u could actually cut the wires and soldern them or use butt connectors and it would be ok?
scrapen is offline
Old 04-18-2009 | 05:48 AM
LOW ET's Avatar
you can do that. cut and solder the wire would be decent but you wont be able to bend the wire where you soldered it. if you want to use butt connectors just get the extension wires. in my opinion the extension wires are the best/easy way to go, i have seen a certain someone on here actually open up the servo and resolder new wires to it that were to the length of his liking.
LOW ET is offline
Old 04-18-2009 | 08:41 AM
The best way is a short servo extension led.
Duster_360 is offline
Old 04-18-2009 | 12:30 PM
Duster_360
http://www3.towerhobbies.com/cgi-bin...?&I=LXTSH5&P=7
cmain is offline
Old 04-18-2009 | 01:27 PM
^^^ Thanks....I have some leftovers from those.
Would still rather use a servo extension - I even use an extension for turning the BEC off in my MM so I don't have to pull the power led out of the Mamba's connection.
