DX3s Telem with dx3r...
Hi, sorta new to the 2.4 world. The dx3s sr3300t reciever will work with the dx3r being backward compatible on the dsm network, yes?, if so what is needed to start using the telemetry with dx3r, I believe you need to buy the seperate module is that correct?, also would it then be possible to watch rpm/speed, temp, battery voltage and the works or only some of the telem available? Help from someone in the know would be greatly appreciated.
I have a DX3S and honestly I find the telemetry pretty useless except for RX battery voltage. The temp sensor is not really that accurate for a nitro car, and I haven't bothered trying to setup the rpm sensor as it serves me no purpose. I found the temp sensor is accurate within 5 degrees up to about 200 and when my engine was running great, about 230-240 the telemetry read 330!! I might not have taken the time to move the sensor around to get an accurate reading, but when I'm racing I can't take time to look down at my radio anyway. Just my opinion, the DX3s is a great radio though.
You have to purchase this.
I thought you would be able to use the SR3300T with the dx3r and go, but no. It was a breaking point for me. Being able to use the dx3r and telemetry with the built in screen would have been a nice feature. But using that telemetry kit with the dx3r makes it no different from any other radio. So now I don't know which one I want. As far as the SR3300T working with the dx3r for basic functions, I think it would. I wouldn't want to personally. I'm sure someone else will come in and answer that one who knows for sure shortly. --pakk |
Originally Posted by markt311
(Post 5682143)
Originally Posted by micknshery
(Post 5682093)
Receiver- SR3000 SR3001 SR3300T These are the ONLY Telemetry-compatible receivers If You're using the SR3000 or SR3001 You will also need SPM1325- On Board Module The SR3300T has that integrated into it From here you can pick up whatever sensors you'd like, or simply get the Nitro or Electric Telemetry Packs (SPM1300- Nitro, SPM1305- Electric). The telemetry pack will also include the SPM1325 on-board module and the sensors. It also comes with the hand held unit (SPM1320). You may want to check out the video I did recently on how-to monitor the main battery pack voltage with the Spektrum Telemetry. It may help answer some of your questions as well.
So you don't need that hand help unit with a dx3r?
Originally Posted by pakk
(Post 5683272)
Originally Posted by RCGaryK
(Post 5683176)
Hey, that's me :)
Ok, so to get telemetry to work with the DX3R you need the following items: Receiver- SR3000 SR3001 SR3300T These are the ONLY Telemetry-compatible receivers If You're using the SR3000 or SR3001 You will also need SPM1325- On Board Module The SR3300T has that integrated into it From here you can pick up whatever sensors you'd like, or simply get the Nitro or Electric Telemetry Packs (SPM1300- Nitro, SPM1305- Electric). The telemetry pack will also include the SPM1325 on-board module and the sensors. It also comes with the hand held unit (SPM1320). You may want to check out the video I did recently on how-to monitor the main battery pack voltage with the Spektrum Telemetry. It may help answer some of your questions as well.
I know enough to just go to the source:nod: |
Will the SPM1305 work along with the DX3S, meaning will both be able to monitor a car's telemetry system at the same time?
(Post 5682093)
if you get the hand held it will work with any spektrum radio |
| All times are GMT -7. It is currently 12:54 PM. |
