-   -   want to upgrade controller (https://www.rctech.net/forum/radio-electronics/289726-want-upgrade-controller.html)
cassidy 04-13-2009 11:55 AM
I want to upgrade the controller for my slayer to 2.4. I have a controller and reciever from a losi slider 1/10th sprint car, will it work in the slayer? If I buy a new controller and reciever for the slayer, do they come in a kit or can they be had seperatley, and if so, what does it take to make the two communicate, will they just plug in and work?
K_B 04-13-2009 12:18 PM
The Losi radio would work, but you wouldn't be able to shift it into reverse because the Losi radio is only 2-channel. You need a 3-channel radio. Something like the Airtronics MX3-FHSS or the Futaba 3PM or Spektrum DX3S/R.
The radio comes with a receiver, so you replace the receiver in your Slayer with the new receiver, bind it, and then set up all the adjustments on the radio to work with your car.
cassidy 04-13-2009 02:48 PM
The Slayer doesnt have reverse, so it would not be a big deal, what do you mean by binding the receiver?
Duster_360 04-13-2009 03:37 PM
Binding is the setup you go thru so your TX recognizes ands looks for only your receiver. Pretty simple affair, not much to it.
