M11 Batteries
What are you guys doing as far as batteries with your M11. I`m using AAs righty now and it eats through them pretty quick. What options do I have with re-chargables?? Thanks
You can go lipo - pricey, but it will not burn through a charge as quickly using this -
http://www.amainhobbies.com/product_...ducts_id/13502 There are others with more capacity that are more expensive. If you stay with AAs, get some quality ones - I use AAs in non RC electronics and use these - http://thomasdistributing.com/shop/-...94gvlt2a22mmj4 I run a 3PKS and 3PJS and use lipo in both. |
Right now I use 2500Mah Energizer NiMhs, they last about 5-8hours, but the have definitely been abused. At one point they hadn't been charged in a year.
Jay |
i use the protek 1100 /11.1 /3 cell its good for 2 race nights and was 27$ or so
Alrighty. Appreciate the responses guys. I just got back from da wally world and got a pack of 8 Energizer e2 2450mah rechargables and the charger for around $40 bucks. Guess we`ll see how this goes. Thanks again guys
I was confused by the 2450mah - but see now that Energizer has re-rated these. I got a set of 8 in a swap and they are good batts as long as you're using them. If mine don't see use for a few weeks, they go flat and have to be charged a few times before using.
Originally Posted by JonNBR
(Post 5577544)
The charger says 15-16hrs per four batteries. They`ve been going since I went to sleep last night. That kinda sucks. :cry: Anyone know how the run time is with these?
Derry, can you specify what your doing? Making a plug that will plug directly into the radio?
Yeah....My local track had the jr plug that fit my trasmitter. Then the hobby shop dude just made me a female deans to jr plug to go from the output of the charger to the input of the trasmitter. I have yet to try it (still waiting for the batteries to show up) but was told it would work fine. I'll let you know how it works out.
Please do. I`ve got to get something else figured out. That energizer charger isnt going to cut it. May end up getting the Lipo.
Originally Posted by gweed
(Post 5577229)
True rc 2650mah transmitter pack fits perfect in the m11 and at 40 dollars its one of the lowest priced quality lipos you will find that fit in the m11
http://home.comcast.net/~truerc/read...eady_packs.htm just click on the tx packs link and it will take you to the 2650 3s lipo. |
(Post 5577229)
Pass you soon |
1 Attachment(s)
(Post 5579726)
| All times are GMT -7. It is currently 02:05 PM. |
