AMP Settings o Hyperion.....HELP!!! >
Old 03-05-2009 | 05:08 PM
Default AMP Settings o Hyperion.....HELP!!!
I have a brand new NiMh I'm trying to charge @ 4.o amps. The 1st one charged successfully at that amperage, however the 2nd one is not charging at more than .10 AMPS. Any suggestions???
vstrok is offline
Old 03-06-2009 | 12:29 PM
K_B's Avatar
K_B
What's the capacity on the batteries you're trying to charge? Try charging it at a lower setting like 2A and see what happens.
K_B is offline
Old 03-06-2009 | 06:11 PM
That sounds like charger is doing a trickle charge which follows at the end of a charge (if its setup). Is this batt already charged by some chance?
Duster_360 is offline
Old 03-07-2009 | 06:42 AM
no....the battery was fresh outta the box. I bought 2 of the same. The 1st charged @ 4a with no problem. The 2nd won't charge above .10a.....weird!!!
vstrok is offline
Old 03-07-2009 | 08:51 AM
I'd see if it will run your rc - try it and it it runs, it was charged, if it doesn't have enough amps when loaded, then I would be suspicious batt has a bad cell(s).
You never know about batts - they don't put manufacture date on them so they may not be the same "freshness".
Old 03-07-2009 | 07:27 PM
Most high end charger will act funny if the settings are incorrect or the battery is junk. They dont act screwy for no reason. Everytime my charger didnt do what I told it, it was because the nimh's had bad cells. Cafefull inspect the battery for a bad solder or something. Just another reason to go lipo.
kasarn is offline
