adding a rx
Old 03-04-2009 | 10:43 AM
x-ray1979's Avatar
Default adding a rx
i just bought a new rx for my futaba 3pk i was wondering how to add it where my two rx are on different models i guess you would say i trieed to select model but i dont know how to change it from m-1 to m-2 any help would be greatly appreciated and thanx in advance
x-ray1979 is offline
Old 03-04-2009 | 02:19 PM
To use the menu, hit "up" , then "SEL" to open menu, should open in level 1, select MDL-SEL, hit SEL, will have the 10model screen displayed, select a new model Number using up/dn. Confirm the change - hit + and - together for 1sec. back out hitting "END".
You're prob not "confirming" your change - hold the + and - buttons down together for 1sec, should see screen kinda blink as it accepts change, then back out using end. If you're not getting there, its the confirm step - keep doing that step until you see radio acknowledge the model change. Believe takes longer to try and explain than to do it.
Duster_360 is offline
Old 03-04-2009 | 03:45 PM
Drifting101's Avatar
It is very easy and quick to change once you learn.
Oh BTW one thing that took me 9 months of use to find was that there is a second menu just to let you know
Drifting101 is offline
