mtroniks rv max
Old 02-13-2009 | 02:30 PM
reg
Default mtroniks rv max
Hi,im just wanting to know if anyone has got one of these,iv got one and its a bit stupid,it only has initial brake,it has no proper brake to stop the car,when you put full brake on it will brake initialy for 1 second then it will just free wheel,the only way you can get it to stop is to only push the brake half way to engage reverse,this will get everything realy hot,
i didnt get the speedo for the reverse,i got it for the no motor limit,but you need the reverse,if you turn it off you have no way to stop the car,
i know you dont need to stop when you are racing,but when i put the brake on to slow the car down for a tight corner i need to know my car isnt just sudenly going to start free wheeling before its slowed down enough and go wide into the corner,i cant run the risk of using the reverse to slow it down,it will eather burn things out in the car or shoot backwards into on coming cars
has anyone else had this
reg is offline
Old 03-25-2009 | 07:18 PM
Bmr4life's Avatar
You sure you have it set correctly? My Genesis Pro brakes like it should.
Bmr4life is offline
