EX-10 and Pro Spektrum >
Old 02-09-2009 | 01:56 AM
PROVK's Avatar
Default EX-10 and Pro Spektrum
Hi
Do you switch your transmiter to Hi-speed or Normal when using spektrum pro module and SRM3100 receiver.
PROVK is offline
Old 02-09-2009 | 06:40 AM
Originally Posted by PROVK
Hi
Normal only
jon123 is offline
Old 02-09-2009 | 02:21 PM
PROVK's Avatar
PROVK is offline
Old 02-09-2009 | 05:07 PM
lil-bump's Avatar
I've always ran mine in fast mode with Spektrum pro with no problems. It does seem quicker.
Pass you soon...
lil-bump is offline
Old 02-09-2009 | 05:13 PM
PROVK's Avatar
Pass you soon...
Lil Bump
I had mine in fast and I had a minor glitch, I am using sanwa anlogue servos.
Can you do me a favour and take your module out of shake it, do you hear a rattle, is that normal?
Or maybe it was that that I had the antenna tip bent with a cap.
What shits me is no glitches with FM and i glitch with a new pro spektrum system
PROVK is offline
Old 02-09-2009 | 06:58 PM
lil-bump's Avatar
Lil Bump
I did the mod to my module so I can not check for a rattle. If you are using analog servo's I would use the normal mode. I run all digital servo's JR 8400 steering and Futaba 9452 throttle.
lil-bump is offline
Old 02-09-2009 | 07:00 PM
PROVK's Avatar
Thanks champ
Pass you soon!!!
PROVK is offline
