Tiny Spark when Connecting Battery & ESC
I use 3300Uf cap on my MM to run 4S and up and its never had a prob - it gets a little warm though. Go over to RCMonster - there's plenty running caps on the MM to enable running higher than spec voltage. Of course the voids the warranty, but if it works....
I run 3 x 3300uf caps on my Quark 125b and that is NOT a little spark on 6S, lol!! Its a loud enough zap that when I make the 1st connection for the day, questions get asked, hehehe. Seriously, BrianG, mod on RCM has a sticky showing how to run a resistor and let caps charge thru the resistor so you don't get the spark. That will save your Deans if you're running HV setup.
