LRP Sphere comp w/ out fan in 4wd
Anyone had any problems running a sphere comp (not the TC with the fan the regular one) in an off road 4wd? I ment to order the comp TC with the fan but go the normal comp instead. Im running a 6.5 in it w/ lipo and was wondering if anyone's had any trouble with them. Just checking to see if i should keep this one or send it back and get the TC...Thanks for the help!!
I ran a TC with no fan and just the heat sink this past weekend with a 10.5 and never had temperatures over 95 degrees with about 7 minutes per run. It was also about 65 to 75 in the building.
I've run a Sphere Comp in both a B44 and a ZX5 with no fans and no problems, pushing mostly 6.5's. No thermals, just make sure you gear correctly and let a little air flow through the body. My motors are always hotter than the ESC. Just don't try to gear it like a higher turn in a 2wd and you should be fine.
I can't remember my exact gearing, but I think I've been running 16-17/78 with the 6.5's. Still has plenty on both ends, but I run on relatively small tracks.
