LRP BL Motor Question...
Just want to verify what I just bought if its functioning normally.
I just bought an LRP Vector motor 4.5turns. I have Novak brushless motors also, now why is it that when I turn the LRP rotor, it's tighter or harder than my Novak 10.5T? Is this normal? The 4.5T feels like a brushed motor. It's not as free turning like my Novak 10.5 motors. Is the magnet stronger or something? Thanks. |
Motor
Bigger rotor
Ok thanks. Are all LRP BL motors like this? Hard to turn?
How about Novak's 4.5R, does the rotor turn easily vs LRP's 4.5? |
Originally Posted by Airflow
(Post 5300105)
How about Novak's 4.5R, does the rotor turn easily vs LRP's 4.5? I have a modified LRP 13.5T BL motor that comes with bonded rotor. I bought it brand new factory sealed combo with LRP Sphere TC. The rotor rotates smoothly, but when I upgraded to larger diameter sintered rotor the motor turns like some restrictions when you rotate it. But now my motor runs cooler than before and I can use bigger pinions/ smaller spur gears on my car. |
Ah ok. So if it's bonded rotor, it will rotate easily and with sintered, rotation
will be harder. Thanks for your reply. |
| All times are GMT -7. It is currently 02:18 PM. |
