Blinky Balancer Questions.... >
Old 01-11-2009 | 10:45 PM
Derry's Avatar
Default Blinky Balancer Questions....
So is it just as simple as plugging your charger into the battery leads like normal (meaning like you would charge a non lipo pack) and plugging the blinky into the tap port of the battery while charging? I have a dura trax 930 lipo charger and a 6000 mh 25 c maxamps lipo.....Should I set the charger to 6 amps while charging? Does the blinky have any limits on how many amps you use while charging? Thanks for any info !!
Derry is offline
Old 01-12-2009 | 04:01 AM
Blinky will balance while charging or function as a standalone balancer. Answer to your ques - yes, plug batt main power leads into charger, plug Blinky into balance tap. Yes, you would charge a 6000mah lipo at 6.0amps - thats a 1C charge rate.
Blinky doesn't see amps, it just works on volts. And will work on up to 6S lipo (22.2v nominal). Can find what serves as a manual here - look for the
"For more information, see the product's PDF file." Near the bottom, the pdf file part id the link.
http://www.astroflight.com/index.php...products_id=21
Duster_360 is offline
Old 01-12-2009 | 11:31 AM
Derry's Avatar
Thanks for the info !
Derry is offline
