Novak Havoc
#91
so any new input?
SO i was thinking about geting a 8.5 havoc system for my pede.
Till i read this have these problems fixed with new fermwere?
or are these problems still happenin
#92
Super Moderator
Trader Rating: 31 (100%+)
Problem fixed, Just don't get one that's been laying around for the last 6 months and your fine.
#94
I sent my Havoc in to get the "update" on it, got it back runs great now. The only thing i would like is more agressive brakes.
#95
Guys i need a little help i am currantly running a airtronics am radio and the 8.5 is glitching on me, I have heard am is not good and have heard it doesn't matter as long as you wire correctly so to speak. However after reading this i am not %100 sure if it just a Tx, Rx issue.. what do you guys think?
#96
Mine fried as soon as it sent power to the motor after the setup was done. It worked for exactly 0 seconds I sure hope Novak stands behind their product, this could be my first and last product from them.
#97
I had the Havoc/13.5 in my buggy and moved it to my new SC10. I just bought the Havoc/17.5 that I want to put in the truck and the 13.5 back in my buggy. Does it hurt the warrenty if I just change the motor on the truck and put the new ESC in the buggy with the old 13.5 motor or do the motor and ESC need to stay togather?
#98
Super Moderator
#99
well, mine fried 2wice
bought a new 8.5 system 4/22. got 30 minutes before it fried, they replaced it for free. then got 10 minutes out of the new one, fried again. this time destroying my 5000 reedy lipo.
will novak replace it again? the form says new 120 warenty so I think so
I also want them to replace my lipo. any sujestions how to go about that?
#100
Well I just got mine back from Warranty, I then wired it upto my 13.5 that was working sweet before the speedy was sent away to get fixed and now it cogs like no ones business.
When I pull the trigger i can see the red and green lights come on saying there is a signal issue, i checked it all and it does the same thing. turns out its the Motor as my 17.5 works fine. Can you get Motors serviced or do you just bin them??
Also, ive tried this a couple of times, when i alter some of the parameters the esc won't go back to just a red light when in neutral...is this correct? It come up with a couple of other lights as well as the red. Only when i redo the 1 touch setting do i get just a red light up but then that over rides any parameter change i made..
I'm glad this is the only Novak product i have.
#101
The Evicerator
And yes the motors can be serviced. If it's under the 120 day warranty simply print and fill out the warranty service form and send it in for inspection.
If the motor is not under warranty, we still offer a non-warranty exchange program that will allow you to exchange your motor for a fresh remanufactured motor for $39 for most motors.
In regards to the lights being on at netural: They are normal... they are simply indicators to you that the settings are different than the default settings... IE if you've added drag brake, you will see a blue and amber LED on at neutral in addition to the red LED.
#102
I gotta say I was treated very well with customer service. like I said up higher I fried 2 havoks and a lipo. I still had to buy a new lipo but novak upgraded me to a GTB for some of my trouble. it will be run tomarow and the biggest race of the year in my area is sat. hope this holds out....if not, its castle creation from now on
#103
R/C Tech Elite Member
