-   -   Arcing/sparking (https://www.rctech.net/forum/radio-electronics/261847-arcing-sparking.html)
asfastasu 12-22-2008 04:35 PM
Arcing/sparking
Hi all, here`s a question for you. When I plug in my Novak Brushless GTB (with the power switch in the off position), to my orion 3200 li-po`s, it arcs when I plug in the last power wire to the battery? Is it the cap.?:confused:
mxzhonkey 12-22-2008 04:53 PM
YES it is the cap taking the voltage out of the battery
Duster_360 12-22-2008 05:29 PM
You should see the arc on a 5S 18.5v system - its gets people's attention, ZAP!! Will eventually eat a deans connector too. For hi voltage systems, you can add a resistor and modify the way you hook it up and basically let the cap charge thru resistor instead of that all at once connect ZAP. Its cool a few times though, especially towards dark.
asfastasu 12-22-2008 07:34 PM
Just wanted to make sure thats what it was:blush:. Thx. for the replys guys:tire:
