LRP Sphere Comp + Spektrum 12th
I'm having 2 problems here:
1) I installed a brand new LRP Sphere Competition in my AE 12R5, soldered everything perfect etc., and when I turn it on, I can steer but even at full throttle my pinion rotates about 1mm each time I hit the throttle, and it beeps every time I do it. I used 2-2-2-2 settings (for 12th scale) and did no modifications whatsoever.
2) I'm having problems using Spektrum in my 12th scale car. In offroad it is perfect, but in 12th scale I can't even steer, the servo gets current, everything working perfect (has nothing to do with my ESC problem, had the same thing with my previous, working ESC), but it doesn't react to my transmitter signals.
Can someone help me out?
As for issue 1)...
you do have a sensor wire connected. Right?
Because that's exactly what happens if there is either no sensor wire attached. Other options are that sequence (A-B-C) is not correct, your motor is damaged or your sensor wire is faulty.
