Airtronics M11X
#1651
#1653
This may be going backwards a bit since everyone has been talking about the M12.
What is the difference in functions between the M11x and the M11? Other than the difference between FHSS-3 vs. FHSS-2 are there any additional features the M11x has over the M11?
I remember hearing that the early M11x still has the M11 screen showing M11 and not M11x.
#1654
Super Moderator
I read that alot have trouble understanding the m11x manual. I have no troubles with it. I do have to look at it from time to time. Too much stuff to try and remember in this hobby.
#1655
You obviously haven't read it very thoroughly - it's an abslute nightmare to try and understand or figure out what Sanwa is attempting to say. Contradictions all over the place and ambiguities abound. Definitely one of the worst instruction manuals I've come across in terms of actually explaining what specific functions do and how best to figure out where to set them.
#1656
Worked like a charm. I am very fluent with my radio now.
Now that I understand settings, reading and understanding the manual is a lot easier.
#1657
hey guys ,
I have screwed up here and put the + on the - on my battery in my car and now my reciever isnt working , is it distroyed or is there a small fuse that i can have replaced and then it will work again ??
Also in my F1 i have a broken case on the Reciever can you order the cases loose ???
Thanks Phil
Thanks Phil
#1658
hey guys ,
Thanks Phil
Thanks Phil
Wow!!!!! What a coincidence. I just did this yesterday.
I run lipo and a straight plug. No switch. I was talking to a neighbor and wasn't paying attention. I noticed my transponders light wasn't on and then I noticed it smoking. I hurried to unplug the battery and the wired burned me. It completely destroyed the battery to receiver wire but only after the Dean connector.
I though for sure my receiver was done. I soldered another wire and went on to drive my truck. I ran two consecutive tanks without a single glitch.
I knew that would happen one day. It was connected backwards for about 10 sec. Pull your receiver cover off and check your wiring. You should be ok.
#1659
I new that would happen one day. It was connected backwards for about 10 sec. Pull your receiver cover off and check your wiring. You should be ok.
#1660
Super Moderator
Most of the stuff I had little to no clue what they where trying explain. That's why I plugged everything in, set my truck on stands and started pushing buttons. I maxed out setting to see what affect they had on steering/throttle.
#1662
OK, my ProTek LiPo's are puffing... Anyone got a better idea out there?
#1664
