My brand new M11 after 3 days is dead!!!! any idea? is there a fuse blowed up? its so easy to fix it my own? Do you know how???
some help please???
Just saying the radio is 'dead' is pretty vague. Did you charge the batteries in it and then it stopped working? Did you drop it and then it stopped working?
Let us know what happened before it stopped working and it may be something really basic. Otherwise, if it's new it should be under warranty. |
I dont remember if i reversed the polarity!!! Yes, i gave up the race for blowed up servo, and when i came back home to test it i puted the battery and nothing!!! Im afraid that i reversed the polarity,but im not so sure!!
can the m11 2,4GHz receiver be blowed up with reversed polarity from the battery???? is that possible???
M11 not centering
My M11 wheel does not go back to center sometimes after releaseing the wheel.Anyone got an idea on what is wrong or how to fix?
Thanks in advance,Rick |
The return spring for the wheel sometimes gets soft. You just need to take the top half apart and ether put a new spring in it or just tighten it up a bit.
| All times are GMT -7. It is currently 12:52 PM. |
