Charging Question for Receiver Packs >
Old 09-19-2008 | 08:27 AM
BLKNOTCH's Avatar
Default Charging Question for Receiver Packs
OK I am wondering if I am doing it right?? I am charging with my ICE Charger and I have the settings as follows:
1500 ma
1.5 amp charge
.9 amp discharge
5mv cut off
Do these look like the best settings? or should I have them sewt different to get better results?
Sean
BLKNOTCH is offline
Old 09-19-2008 | 08:41 AM
For rx batts you don't want punch, you want time, so they're not generally not charged at over 1amp, versus the 1C guideline. You'll get better life at the lower charge rate too. When I have time, I charge mine at 0.5a - 1a is considered a fast charge and 0.5a a slow charge for rx batts.
You can use the 1.5a rate if they're not getting hot if yu don't care how long they last (cycles). Mine would be too hot charging at 1C.
Everything else looks fine.
Duster_360 is offline
Old 09-19-2008 | 01:08 PM
BLKNOTCH's Avatar
Great Thanks for the info, I have lots of time so I will start charging at .5 from now on.
Sean
BLKNOTCH is offline
