Did I just kill a lipo?
I bought some intellect lipo stick packs that came with Tamyia plastic style connectors on them and I'm replacing them with Dean's plugs.
So, I get out the wire cutters and cut the plug off the battery - both wires (+ and -) in one go. ZAP! Of course I short out the battery as the wire cutter is metal and the + and - terminal of the battery are now connected. Smells something horrid and made a mess of the wire cutters too. Wires would have been in contact for about 2 secconds or less.
So, not having entirely cut off the plug yet, I hook up the battery to one of my cars still using a Taymia style plug. At first the nothing and I thought the battery was a gonner. But then the car came to life and operated just fine (for a 10 second test). I repeated this a couple of times and the car appears to work just fine.
Is this battery dead or should I continue to use it?
Will it flame out after prolonged use now that I have shorted it?
Is is now damaged and could possibly give an unstable current / voltage and ruin the electrics in the car?
Maybe I should post this in the Rookie zone as what not to do. I'll only ever make this mistake once...
Should be ok, Ive seen bullet connectors touch (briefly) many times without causing any permanent damage. Watch it for the first couple of charges, maybe even charge them outside just in case. Also, if it starts to puff up then its time to get rid of it before something worse happens.
