HELP lipo regulator question
Hi does anyone know if there will be a problem if I dont run a regulator with the following setup,
receiver is a spektrum pro servos are both futaba s9152 transponder is amb battery is 1300mah 7.4v premium power transmitter 3pks can I run without a regulator last week I ran 4x5min races and 1 20min main no problem but I just want to double check if its ok to continue?? cheers:) |
hi,
u risk frying yr servos and AMB if their rated input is 6V only. :nod: why u wanna remove the regulator? i'll fit the regulator for a peace of mind. :) |
Not sure about your servos but when i had my brushless 1/8 i ran a BEC set at 7 volts... Servos with a heatsink case are no problem.
My personal Trans didnt seem to be affected either but i wouldnt recomend it if your worried about it. |
cheers for that 2 things
finding a good spot to fit the regulator is a pain and secondly i was running a 2amp regulator which was not enough as i had glitches in power I obviously need a 5amp regulator. thanks again:) |
Originally Posted by aussies1129
(Post 4828043)
finding a good spot to fit the regulator is a pain and secondly i was running a 2amp regulator which was not enough as i had glitches in power I obviously need a 5amp regulator. thanks again:) my buddy is using the same regulator+lipo as yrs. :sweat: |
I have had it on the starter box with all electrics on and when I operate steering and throttle that the light goes out on the amb and every now and then the throttle would surge to wide open throttle and come back in a second to idle. thats my problem I think its a surge problem between servos steering and throttle and the amb cause the regulator is only putting out 2amp but when i took the reg off it ran perfect??not a drama at all??
cheers
Originally Posted by NitroWD
(Post 4830179)
care to describe yr glitching problems?
| All times are GMT -7. It is currently 12:14 AM. |
