Charge two batts with EOS0606i...?? >
Old 08-12-2008 | 03:50 AM
RCRat's Avatar
Default Charge two batts with EOS0606i...??
Can someone help me figure out how to charge two batts with an EOS0606i
For example 2 x 2S Lipos 4000mah
I found this link but I'm not sure this works for the EOS0606i and the links to the LBA10 adapter don't work....so I need help wiring etc...
http://www.nitrokillers.com/showthre...=8731#post8731
RCRat is offline
Old 08-13-2008 | 02:46 AM
RCRat's Avatar
No One? Anyone?, Anyone?.........Bueller?
RCRat is offline
Old 08-27-2008 | 03:30 PM
rcman1993's Avatar
pretty much all you need is a y harness and that will put the lipos into a series and that will be chargable. i wouldn't try in myself because i have that charger so its all up to you.
rcman1993 is offline
Old 08-27-2008 | 03:31 PM
rcman1993's Avatar
look at max amps, they have stuff you can but for the charger and diagrams i believe, hope that helps.
