-   -   starterbox battery charging (https://www.rctech.net/forum/radio-electronics/234824-starterbox-battery-charging.html)
Allumina 07-30-2008 08:42 PM
ey my ofna starterbox has two 6 cell 1500mah packs in it [like the kind of pack you run in an electric car] I need to charge them up so I can start breaking my motor in tonight, you think around 3 amps is ok? lmk thanks
JeromeK99 08-01-2008 12:36 AM
If they are 1500mah they might be NiCads... if they are 3 is probably pretty low.. 5 or 6 amps should be ok.. If they are NiCads make sure your charger is set correctly.
What kind are they? Is there label on them or brand?
Jerome :tire::tire:
Bulldawg RC 08-05-2008 07:10 AM
i remember the good ol days of racing with nicd's. i use to charge my 1500 sport packs at about 4 amps and then peak them off at 5 amps. 3 amps should be fine to charge it. just always keep an eye when charging.
