Lipo Balancing Help
Old 07-24-2008 | 06:25 PM
dougyunker's Avatar
Default Lipo Balancing Help
I'm using a Duratrax ICE charger, Trakpower balancer and lipos. When I try and charge/balance from my charger through the balancer to the lipos, my ICE says that there is no battery connected, beeping. All of my connections are good and my charger charges the lipo without the balancer just fine. What gives? Thanks, Doug
dougyunker is offline
Old 07-25-2008 | 04:00 AM
jla8874's Avatar
You have to push the MODE button on your balancer to swith from disconnection to connected mode. Your charger cant see the lipo because there is an open circuit in the balancer. You can balance stand-alone with out charging, but once you hook it to the charger you have to change modes.
jla8874 is offline
Old 07-25-2008 | 05:08 AM
dougyunker's Avatar
I did put it into link mode but it didn't help. I guess I'll just use it without the charger. Thanks, Doug
