Battery Charging Question >
Old 07-12-2008 | 06:51 AM
Default Battery Charging Question
have a very old AC/DC MRC battery pack charger. This charger just has a timer and a meter. I know when i bought this years ago most guys had to manually peak their packs with a meter. Does anyone know the procedure i would like to use this charger for a few weeks until i can replace it. Thanks and i dont want to harm my new battery packs. I have a 1600mah and a 3000 mah 7.2v packs.
As always thanks
term_paint is offline
Old 07-12-2008 | 02:42 PM
Watch the pack voltage as it goes up, when it levels out stop the charger. Or at least before it drops much. Much being about 0.03v for a 6 cell pack to be safe. Make sure the old meter is working well enough, might be a wise idea to use a separate digital meter if you have access to one. Also keep tabs on the pack temperature, it will heat up as it reaches full charge, you don't want to get to the point where it's uncomfortable to hold.
Dave H is offline
