I need servos. Recommendations?
So just like the title says. I need to pick up two servos. I'm gonna be running 1/10 nitro. Either an MTX-4 or a Kyosho V-One RRR. I'm not looking for anything too expensive but not too cheap either. Somewhere in the $50-$70 range. If you could recommend a cheaper one thats still good, then I wont discriminate on that either. Also, should I get both high speed servos for throttle and steering or one high torque and one high speed?
If you could leave the model numbers that would be cool so that I can try and locate one.
Look for the following servos:
Futaba 9450, 9451,or 9452. You can use any of those in either spot on your sedan.
Currently I run the 9452 for steering and the 9550 for throttle.
I will be installing the newer 9551 soon. There are usually lots of good used servos available on this site.
Well if you plan to let go of any of those anytime soon, PM me. I might be able to pick up just one of those at this time if its a fair price.
I have a 9450 servo I can let go of now. I dropped it and it is missing a part of one of the mounting ears. I still used a screw on it, but it is not 100%.
Cord and plug are fine. Case is fine except the ear. You can see it in the picture.
$35 shipped in the USA. LMK
YGPM
