TURBO 30 HELP
Old 05-01-2008 | 11:25 AM
17nut's Avatar
Default TURBO 30 HELP
Hey i just picked up a turbo 30 in a trade
What can it charge? is there anyone who has the directions for it? will it charge 4200's? do you have to do anything special to charge them? Thanks in advance
17nut is offline
Old 05-02-2008 | 01:19 PM
17nut's Avatar
anyone got any info
17nut is offline
Old 05-03-2008 | 06:55 PM
Should be able to charge NiCad and NIMH. You can get instructions on Competition Electronics website.
nutz4rcyktw is offline
Old 05-06-2008 | 07:34 AM
pc9840's Avatar
Moderator
17nut -- Is this the plain turbo 30 or the turbo 30 turbo flex? (Turbo Flex has 9 buttons Turbo 30 has 5).
If its the original then it has a 3000mah output limit so you would need to repeak your batteries to get a full charge.
If its a Turbo Flex then you can get a Eprom upgrade that will remove the output limit and it will charge all current nimh and nicd. I think the eprom chip is like $25 and you can install it yourself.
pc9840 is offline
