-   -   Strange Speedo Issue (https://www.rctech.net/forum/radio-electronics/208765-strange-speedo-issue.html)
UltegraSTI 03-02-2008 06:32 PM
startin in main last wk and again thru mtg this wk, i've run into a strange problem with my stock class m18. here is its configuration.
m8-spektrum
3500 Rx
hitec servo
GM SX3 esc
180 mini mauler motor on 6cell 700mah batteries.
here is my issue, i get a drop in the throttle as i pull the trigger back, causin a 'bucking' or 'spiking' feel. thought i was hits til i slowly pulled throttle back lookin for a driveshaft vibration. it would ramp up til about 2/3rds throttle, then drop down and stay, til i pulled further when it recovered on the way to WOT. if i would start lettin off the trigger from the dead spot, the speed would spike up. over and over if i went back and forth.
the stranger part is that if i do a simple reset on the controller (neutral--gas--brake). its gone. it lasts bout 2 packs, then its back, simple reset, gone again. i tried 3 different maulers wonderin if i had winding issues. not the case. but a reset takes it away.
in 20yrs, i havent seen anythin like this, thoughts?
R
UltegraSTI 03-09-2008 06:26 AM
update
speedo wont hold its program, i have to reprogram throttle and brake curve just b4 i run, have to keep it all plugged in with the battery i'm usin for the rd. it does work after i reset the curves, but its highly annoyin, never run across this. any thoughts!!!
R
