-   -   GTB profile (https://www.rctech.net/forum/radio-electronics/207875-gtb-profile.html)
burris7555 02-26-2008 12:25 PM
GTB profile
Which profile on the GTB would my 17.5 and 13.5 benifet most from, as far as power? Thanks
chazman 02-26-2008 02:43 PM
well im assuming (i know assumption is the mother of all f**k ups but...)that u dont use reverse so number 4 i think will give u what u are after
burris7555 02-26-2008 05:19 PM
Sweet.... Thanks. Would the optional 13mm rotor help as well?
daveaustin5 02-26-2008 05:23 PM
What's the deal with the different profiles? Are some better for different types of racing? I race TC carpet rubber 10.5, what profile would best suit?
burris7555 02-26-2008 05:36 PM
I wasn't sure on what one I would get the most out of my 17.5 and 13.5 motors. A GT7 I had a while back has a mod profile, an oval and stock, along with others. I just wanted to ask which would be more beneficial for my SS motors...
UN4RACING 02-26-2008 09:43 PM
This might help?
http://www.teamnovak.com/tech_info/index.html
http://www.teamnovak.com/tech_info/e...min/index.html
chazman 02-27-2008 03:17 AM
the 13.5 rotor dose help alot
from my experiance on 13.5's number 4 gives u more punch i belive but it also is much better on the braking side of thiongs as when i started on profile 1 i found there was little braking went to 4 and now it stops on a dime ;):sneaky:
totalazneclipse 03-05-2008 01:56 PM
Is this using the preset profiles or using that certain profile and programing it also?
air8 03-05-2008 08:04 PM
For practicing I use profile 5, I think. The one with reverse but still programmable. That way I can still back away from the pipes if I cut the corners too tight.
For racing I use profile 1 with the drag brake off and the initial braking turned down low, and then the initial acceleration turned up for 13.5 For mod motors I turn the initial acceleration way back down.
It's very easy to change the profiles. The manual explains it in their terms so reading through and understanding it before making changes would be good to do. After that just have fun and play around during practicing.
