Hudy tech lathe help >
Old 01-28-2008 | 04:14 AM
dragon26's Avatar
Default Hudy tech lathe help
Hi, I just bought a second hand hudy tech lathe and I've set it up with the tip just above the center of the comm and have it spinning the correct direction but it is leaving serrations in the comm. I'm using v guides and shimming the armature a little bit to eliminate the play.
Any help greatly appreciated.
dragon26 is offline
Old 01-28-2008 | 12:54 PM
d4man's Avatar
What kind of cutting tool are you using? If it's Carbide, throw it away and get a Diamond Bit. It will last longer and cut better. Those carbides bits work good, but the dull quickly.
d4man is offline
Old 01-28-2008 | 02:54 PM
dragon26's Avatar
Default diamond
Its a diamond tip.
dragon26 is offline
Old 01-29-2008 | 09:44 AM
d4man's Avatar
Is it damaged??
d4man is offline
Old 02-01-2008 | 08:28 AM
DFroyd's Avatar
Tried varying motor speed or how fast you turn the wheel for bit travel??
DFroyd is offline
