Spek Conversion on M11
before i go yanking it apart, is there anythin i should know....in terms of being different than for the m8 (i still have that unit as reference).
thank you for your help in advance. R |
I think they are close to the same inside.
there the same, just make sure you dremel the antenna hole big enough,
i didnt do big enough then like 6 months later hair line fractures started appearing |
| All times are GMT -7. It is currently 10:17 AM. |
