Trinity Li-Pro 4500 Racing Pack >
Old 12-11-2007, 03:31 PM
  #31
Midnight's Avatar
Trader Rating: 87 (100%+)
Same weight as the peak 4800, height same, length same, width is about 1/16 wider. Fits perfect in my b4 and t4.
Midnight is offline
Old 12-11-2007, 04:00 PM
  #32
VOODOO+'s Avatar
Sounds like everything else is pretty much in order. How's the performance and run-time?
VOODOO+ is offline
Old 12-12-2007, 11:48 AM
  #33
Midnight's Avatar
Well when I went to plug the leads into the battery, they were opposite compared to the peak. I want be able to run them until the first of the year when the track starts to allow them.
Midnight is offline
Old 12-12-2007, 05:16 PM
  #34
Brian Miskolczi's Avatar
Trader Rating: 162 (100%+)
Here are some pics of the pack. I also scanned the instructions so everyone can have all of the information about these packs. From full charge in a touring car witha brushless motor, depending on your track conditions and gearing it will go 15 mins until the internal volatage cutoff will automatically shut it off.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Brian Miskolczi is offline
Old 12-21-2007, 05:53 AM
  #35
QuickRC's Avatar
I've done some testing on these they seem pretty decent. Attached is a 2 discharge plots I made at 30 amps. They are a little on the low side and there is a dip at the beginning of the discharge because these cells were sitting in my shop all night and were a little cold in the morning. Once the cells warm up a little (from discharging) the voltage rises a little.
Weight on these is about 8.5 Oz or 240 Grams. They are 1.83 in/46.7 mm wide, 5.4 in/137.39mm long .937 in/23.81 mm thick. Basically, almost identical to an assembled side x side pack. The low voltage cut-off that is built in does work and kicks off at 5.4 volts on the nose. Good for a safety measure but don't run them until they hit the cut-off if you can help it. It's best to stop once a noticeable decrease in speed happens. I think 5.4 V was probably chosen as 6.0 V would be too agressive and under load you would experience drop-outs - 5.4 V is a good number. Testing was done on a CE Turbo 35 GFX LiPo.
QuickRC is offline
Old 12-30-2007, 02:23 PM
  #36
Alltapdout's Avatar
Does anyone know what balancer to use on the reference pack??
Alltapdout is offline
Old 12-30-2007, 05:59 PM
  #37
Davidka's Avatar
Trader Rating: 86 (100%+)
Thanks for that info, very informative. Have you tested other LiPos and Nimh too? I'd be interested in how well these compare.
Davidka is offline
Old 12-31-2007, 02:13 PM
  #38
cla5675's Avatar
Trader Rating: 49 (100%+)
Thumbs up
It's the Align balance plug.
I've been using this battery in 10th scale touring cars and buggies with brushed motors and no lipo cut-off. It's working as well as my Pro Match EP4200 packs with a CO27 stock motor. I've also been using the Hyperion EOS0606i AC/DC charger and that thing is awesome. Can't believe there would be a better all around charger for $150.
cla5675 is offline
Old 12-31-2007, 05:41 PM
  #39
if i used a lipo pack what would i need to make it work?
mr2sd is offline
Old 12-31-2007, 06:48 PM
  #40
PitNamedGordie's Avatar
Just a lipo charger...like a Duratrax ICE or a Hyperion EOS0606i.
PitNamedGordie is offline
Old 01-01-2008, 05:41 AM
  #41
Alltapdout's Avatar
So I have an ICE charger, can I just use my astro blinky balancer on this pack? I don't see why I couldn't but all the info I'm reading says I need a balance/charger which is intrigrated. Not just a seperate balancer.
Old 01-01-2008, 06:14 AM
  #42
magm20001's Avatar
any comparisons to a decent IB/EP4200 matched pack?
magm20001 is offline
Old 01-01-2008, 06:15 AM
  #43
magm20001's Avatar
blinky is fine. they just dont provide the digital readouts like a integrated charger would.
Old 01-04-2008, 05:50 AM
  #44
QuickRC's Avatar
Sorry fo the slow reply - been out of town a lot lately for the holidays. Yes I have done some comparisons. I'll post some more plots this weekend. BTW, my GFX seems to be a little stingy on the capacity rating. It's giving me about 4400 mah on these but also gives about 4400 mah on a brand new EP4600 pack that just came of the matchers.
I'll try to get some more data posted this weekend.
QuickRC is offline
Old 01-05-2008, 09:43 AM
  #45
Trader Rating: 58 (100%+)
Anyone have any problems with the 2 hard case halves having some play?
If I press and release the front near the inputs the case moves about 1mm up and down.
Worst case, I'll just run a band of tape around it, but curious if others are like this?
WHOBEE is offline
