Team Tekin New Speedos >
Old 10-18-2006, 02:38 AM
  #16
Post
i hope these come out soon. how much do u think they will cost?
myk505 is offline
Old 10-18-2006, 02:51 AM
  #17
tc3team's Avatar
The smaller size is going to be a god send to a lot of the TEKIN die hard fans and to others who had previously looked away because of the g10/g11 size
Looking forward to these coming out a lot!
tc3team is offline
Old 10-18-2006, 03:41 AM
  #18
Trader Rating: 58 (100%+)
Why only 5V BEC???? Please tell me this is a misprint and they are actually 6V?
WHOBEE is offline
Old 10-18-2006, 05:08 AM
  #19
Looks like the lowest on resistance of any esc. Wonder what the weight is.
porschejim911 is offline
Old 10-18-2006, 05:33 AM
  #20
Isaac's Avatar
All I need to know is when it's coming out.
Isaac is offline
Old 10-18-2006, 05:34 AM
  #21
rogtsaamokin's Avatar
anyone heard of an exact date for the new speedo, who will have it first ???
rogtsaamokin is offline
Old 10-18-2006, 11:42 AM
  #22
The weight will probably be similar to any other small top of the line esc (around 18 grams) I just placed my vfs 1 pro up on the screen to compare to the size and this Tekin esc is about 5mm wider i think.
savageguy is offline
Old 10-18-2006, 01:28 PM
  #23
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
I'm with you!!!!!!!!!!!!
wyd is offline
Old 10-18-2006, 01:34 PM
  #24
They look very good, but why only 5volt? And can these be run with 4 cell 12th scale?
jeffb is offline
Old 10-18-2006, 08:20 PM
  #25
coons88's Avatar
The 5v BEC puzzles me too
Looks good, I really like the size!
coons88 is offline
Old 10-18-2006, 08:49 PM
  #26
Team EAM
Trader Rating: 79 (100%+)
Originally Posted by rcnewb2004
a bit off topic, does anti-drag=creep?
Yes I think it does also known as "roll" by some. I spoke with Jim in Vegas and he said that the new speedo would have that feature built in.
EA
EAMotorsports is offline
Old 10-19-2006, 02:47 AM
  #27
Originally Posted by DA_cookie_monst
Not realy, it means when you shut the throttle off it will apply a small amount of power to the drive fets, to stop a stock motor braking to hard due to motor breaking.
I've never head of that before, whats the best way to set this on the radio? turn up the trim just 1 step before the car starts to crawl?
I cant find sizes on the ko site but the twister 2.1 specs at 28.0 x 25.0 x 14.4mm compared to the tekin at 25 x 20 x 19 overall its smaller.
But do tekin require us to use caps and big diodes?? or can we save even more space?
8800 is offline
Old 10-19-2006, 03:15 AM
  #28
I am not sure as yet about the BEC, but I shall find out for you asap.
Power Cap, probably will have to, but the Tekin power cap is a small unit, selected so that it will sit on top of the ESC, the reason for this, is you can keep the leads very short, which also allows a smaller value capacitor to be used. The Power Cap is also a high quality unit, not a cheap 'off-the-shelf' cap.
DA_cookie_monst is offline
Old 10-19-2006, 04:49 AM
  #29
wow those pics are decieving. its gonna be 19mm tall where as other speedos are alot thinner. still good though!
wat is this BEC 5v thingy? what is it and y is it bad?
myk505 is offline
Old 10-19-2006, 05:58 AM
  #30
tc3team's Avatar
If its anything like the G11 cap it wont be big Some of the Novak ones ive seen dwarf the G11 one!
tc3team is offline
