Sanwa m17 live data twitching >
Old 05-06-2025 | 12:47 PM
Default Sanwa m17 live data twitching
On my new sanwa m17 the live data of the throttle just rapidly between 0% and -2%. Actually got lucky and when i snapped this pic you can see it changing. Any thoughts? Should i send in? Is this normal, should i adjust the screws for what this has? Thanks all. Also i guess i don’t have enough posts to post pic
Last edited by B_B_Q; 05-06-2025 at 12:48 PM. Reason: Pic removed since i guess i have to hit a number of posts first?
B_B_Q is offline
Old 05-06-2025 | 01:01 PM
gigaplex's Avatar
If it's new then I'd be returning it. That's a sign of a dirty or worn out potentiometer.
gigaplex is offline
Old 05-06-2025 | 01:29 PM
Okay noted on that. I thought i’d try doing tension screws first to see if it was just off a little. Ill take it apart and see. Then go from there.
B_B_Q is offline
Old 05-08-2025 | 12:26 PM
jdearhart's Avatar
If it's brand new, send it back. If it's new to you, you can sometimes blow the trigger area out with compressed air or try to spray it out with electronics cleaner. Then I'd recalibrate it and see if it's still jumpy.
jdearhart is offline
