Brushed Motor Wiring Help >
Like Tree2Likes
  • 2 Post By biz77
Old 03-20-2025 | 04:25 PM
lifeofbrian's Avatar
Default Brushed Motor Wiring Help
I've just purchased my first brushed motor in over 30 years and want to make sure I wire it correctly. It's an LRP V10 Spec6 - 12 x 2. I assume the top half is positive {blue wire}, but does it matter which tab I solder to, and why are there 4 tabs in total? Does it just go backwards if I wire it the wrong way around?
Thanks.
lifeofbrian is offline
Old 03-20-2025 | 04:37 PM
Yes, top half is "+". Either tab on that side will work. The two tabs per side is just for ease of wiring. If you wire backwards, the only effect is it runs backwards.
lifeofbrian and OffRoadJunkie like this.
biz77 is offline
