Too much throttle before B7 accelerates
#16
I just got back into 10th scale racing since my town finally has a track. Been out of the hobby for 10 years so feel like a newb again. I just assembled a Team AE B7 and I'm using a HW xerun xr10 stock spec g2 with a 21.5 motor and flysky transmitter and receiver. It seems like I have to give the car way more throttle to get the tires to start turning than what I remember. My transmitter is showing 20% throttle before the tires start spinning even sitting on a stand. Does this seem right? Once the tires start spinning it's like the drivetrain is out of balance as tires fluctuate in speed. What should I start looking at? Thanks for any help.
#17
The motor has a lower sensor port and is where my sensor wire is plugged in. Hard to see on the video I posted. Should I be using the top port instead?
Thank you for the soldering tips and recommendations. I'm definitely rusty on my soldering skills with my lapse in being in the hobby
#18
Just wanted to come back and update this thread. I appreciate everyone's input and help. Swapped out to a different sensor wire and used the programmer to help tune the throttle. As for the variation and out-of-round tire rotation; I ended up flipping on side of my diff height inserts which was causing the rear diff to be misaligned. Solved my issue.
19Likes
