-   -   Replacing wires on Elceram ESC? (https://www.rctech.net/forum/radio-electronics/1124379-replacing-wires-elceram-esc.html)
Cavi Mike 06-05-2024 05:28 PM
I’m really intrigued by these new ESC’s but I can’t find any information on how to access the solder posts. Does anyone have one of these yet and care to share some photos of if it’s even possible?
hunterdawg 06-05-2024 05:39 PM
I spoke with Elercam, they said no due to design.
malkiy 06-05-2024 06:58 PM
I was really interested in their new ESCs but then I saw how the wires attach. Have no idea why they would go with that design of soldering the wires directly to the PCB.
Sanchez 06-05-2024 07:01 PM
You'd think for an upmarket esc, that a simple design flaw like this shouldn't be an issue.
gigaplex 06-05-2024 07:04 PM
That's an odd response considering that the instruction manual shows how to open the case and lists a part number for replacement wires.
hunterdawg 06-05-2024 07:26 PM
Just relaying what elercam sent me in an email.
Geezatec 06-05-2024 08:43 PM
Replacing wires on the board would void you warranty what ever it is. You got plenty f wire to customize length. Use XT60 or 90's for lipo. A,B,C, motor wires use bullet connector in b/n ESC and motor, this was you change the motor, easy to replace! Its customization! to length.
gigaplex 06-05-2024 08:57 PM
Almost anyone using an ESC of this calibre will be using bullet plug batteries, not XT*0, and will directly solder the motor wires. Moving the ESC between vehicles might require different length wire, or wires can get damaged and need replacing.
Cavi Mike 06-05-2024 10:28 PM
First of all - no one uses XT connectors or any connectors of any kind on their cars. I’m not sure what kind of basher nonsense you’re driving but you definitely don’t deserve that “tech master” badge giving advice like that. And replacing ESC wires is not grounds for voiding warranties either.
Roelof 06-06-2024 01:27 AM
Well, opening a device can be enough for voiding warranty. Damaging parts while disassembly is for sure a void of warranty. Not soldering right and making shortcuts.... who would give warranty on that?
On the other hand, yes, spare cables are listed so somehow a replacement by user or manufacturer should be possible.
And why are they directly soldered on the board, simple: to lower resistance. Any solder joint and/or connector is a resistor
DirkW 06-06-2024 03:16 AM
You really give a crap about these stupid auto-assigned forum ranks/titles? They are not based on any skill or experience whatsoever. Usually these systems are only based on number of posts of the user in question.
EricW 06-06-2024 04:56 AM
It is illegal in the US for a manufacturer to void a warranty for opening something up and replacing parts. United States Federal Trade Commission Cracks Down on Voiding Warranties For Unauthorized Repairs and Parts | Cassels.com
Roelof 06-06-2024 05:03 AM
Ah nice. But then, if you damage something then still warranty will be an issue I think. Over here there are warranty rules but still many shops and manufacturers try to work around them. But the EU is busy with a so called law "right to repair" that will have a huge change on products.
Cavi Mike 06-06-2024 06:54 AM
Is there anyone that can answer my actual question and stop speculating?
hunterdawg 06-06-2024 07:22 AM
If you can't get the "right" answer here, maybe contact Elercam directly. They responded in a timely fashion to both of my questions.
