Reedy 510R help
Turns on solid green light. Fan runs and steering works. Give it throttle or brake esc turns off. It worked great last time I used it and didn't change anything. Things I have tried are couple different batteries, recalibration couple times,& complete reset on the programmer. All soldering and wires look good. Any help would be greatly appreciated. I have tried reaching out to Reedy with no response.
Fan on & Steerinn operates, tells me your Binding is good. Calibrate your ESC, see 510R manual, it calibrate the position of Neutral, Full Throttle abd Braking. Each position hold a second till LED toggles or beeps. Then turn restart your radio system.
1Likes
