Like Tree8Likes
Which hobbywing esc
Old 02-18-2024 | 03:41 PM
Onroad tourer's Avatar
Default Which hobbywing esc
Hi, I'm looking for an esc for a 1/10 2wd buggy for carpet racing, currently use a 8.5t motor.
I currently use the Hobbywing Xerun Xr10 Pro V4 G2S Speed Control – Black for my touring car and have the Bluetooth module
However I was wondering if Hobbywing Xerun Xr10 Pro Speed Control – Black would be much different as its significantly cheaper and it looks like I could still use the Bluetooth module with it?
Any advice would be greatly appreciated
Onroad tourer is offline
Old 02-18-2024 | 07:56 PM
I assuming you’re comparing the old xr10 pro legacy vs the current g2s. I upgraded all my old 160amp hobbywing v4 legacy to the current g2s for 2 reasons. First reason I like the fact the g2s has reverse polarity protection. If I plug in the battery backward the esc wont blow up. Second is the g2s is compatible with the hobbywing to futaba s. Bus adapter. I use a futaba 10px and I love the fact I can see the battery voltage,motor temp, esc temp and motor rpm all just by looking down at my radio screen.
riceball777 is offline
Old 02-19-2024 | 08:57 PM
I'm about to pick up a used Hobbywing 160A Xerun XR10 Pro G2. I'm not really up to speed with the Hobbywing line up, is the product name enough to identify the age/generation of the model?
Zoomies is offline
Old 02-19-2024 | 09:14 PM
gigaplex's Avatar
The G2 suffix is enough in this case. It's one generation old but has nearly all the features of the G2S.
gigaplex is online now
Old 02-20-2024 | 05:02 AM
petersen114's Avatar
[QUOTE=riceball777;16078329 First reason I like the fact the g2s has reverse polarity protection. If I plug in the battery backward the esc wont blow up.[/QUOTE]
It will fry the cap pack if this happens though.
petersen114 is offline
Old 02-20-2024 | 05:43 AM
gigaplex's Avatar
Hobbywing sells non polar capacitor packs for that purpose.
petersen114 likes this.
Old 02-20-2024 | 07:51 AM
DirkW's Avatar
Yes, but as an extra. It's unfortunately not part of the G2 package.
DirkW is offline
Old 02-20-2024 | 01:53 PM
That is correct but first of all this is not a big deal as the capacitors are cheep and easy to replaces. Also they sell non polarity capacitors which i do run.
Old 02-20-2024 | 01:58 PM
Garet Jax's Avatar
Is there any special configuration required to get all those details on the radio? Does it require the latest receivers?
Thanks.
Garet Jax is offline
Old 02-20-2024 | 02:25 PM
Thanks.
https://www.amainhobbies.com/hobbywi...50500/p1391362
You must have a hobby wing g2s esc. Will not work with the g2 esc. I think this only works with the futaba 10px.
Garet Jax likes this.
Old 02-21-2024 | 08:40 PM
Thanks Gigaplex.
I've picked this ESC up to run in a stadium truck with a 7.5t Reedy motor - I'm just returning to the hobby and not sure if I should run a fan on both the motor and the ESC?
Where do the fans connect? I've got a 3ch receiver, where the spare is taken up with transponder. Does the ESC support two fans?
Zoomies is offline
Old 02-22-2024 | 04:36 AM
DirkW's Avatar
At least the Pro versions do. The ESC fan uses a tiny connector, and you can run a regular motor fan (with servo connector) and power it through the slot where you can also plug in your programming card / WiFi/Bluetooth device.
gigaplex likes this.
DirkW is offline
Old 02-22-2024 | 09:34 AM
What is that module you have plugged into the programming port and receiver?
Sabin is offline
Old 02-22-2024 | 10:23 AM
just click the link. It the hobbywing futaba telemetry s bus adapter. Its a small adaptor/chip that one end plugs in to my hobbywing g2s esc and the other end plugs into my futaba receiver. This will let me see things on my radio like my motor temp/ esc temp/ battery voltage and charged %/ /motor rpm and much more
Old 02-23-2024 | 03:54 AM
gigaplex's Avatar
It's a cool little unit but check with your local racing body to see if this is race legal. Often having anything with communications plugged into a programming port on the ESC is illegal, to eliminate the possibility of turning boost on and off remotely.
